OneGigMan
Oct 30, 2022Aspirant
WAX630E not outputting Wifi 6E
I have an Xfinity XB8 Tri-Band modem that outputs WiFi 6e. I added a WAX60E access point, but it's not outputting Wifi 6e E....just wifi 6. Attached are my settings for that SSID. Can anyone help me out here?
- OneGigManAspirant
OneGigMan wrote:
I have an Xfinity XB8 Tri-Band modem that outputs WiFi 6e. I added a WAX60E access point, but it's not outputting Wifi 6e E....just wifi 6. Attached are my settings for that SSID. Can anyone help me out here?Probably one to ask on the appropriate section for the WAX630E:
Business Wireless - NETGEAR Communities
How do you know its not putting out 6ghz?
- OneGigManAspirantThe WiFi indicator on my phone only shows "6" not "6E" like it was before I added the access point
1. what phone do you have?
2. Is it connected to the access point?
3. Do other devices not see the 6gh?4. If you disable the 2.4ghz/5ghz signal, does the phone still see the network?
5. Are you using bandsteering? Single ssid function?
- OneGigManAspirantAlso, when I made the new SSID with only 6ghz enabled, not only do I not see it, my phone suddenly saw my 6E that my router is outputting and connected to that (not the access point). Besides this new SSID I just created, my other SSID's on KY access point have the same username and password as my router SSID's.
