ToniRod
Jul 23, 2023Guide
WAX630E VLAN bug
Hello, I'm having issues with my 2 WAX630E units. VLANs are not working properly. Configuration: - Netgear MS510TXM Managed switch - 2 WAX630E AP, AP1 and AP2 - 2 VLANs: A & B - 2 SSID:...
rivadavia
Feb 28, 2024Tutor
I'm also facing this exact same issue. The TCP session connects to the wireless device on a different VLAN but it will not pass traffic. Ping also works. This only happens if the two wireless devices are on the same AP but different VLANs. This is a significant bug. Can we get an update or do I need to return this product? I have verified it is not a router/firewall problem.
Thanks
