ToniRod
Jul 23, 2023Guide
WAX630E VLAN bug
Hello, I'm having issues with my 2 WAX630E units. VLANs are not working properly. Configuration: - Netgear MS510TXM Managed switch - 2 WAX630E AP, AP1 and AP2 - 2 VLANs: A & B - 2 SSID:...
rivadavia
Mar 01, 2024Tutor
I opened a case and spoke with support who stated that the problem is being actively worked on but that they can't make any claims about when the fix will be released. I guess I will be keeping the device and eagerly awaiting the fix.
- gregd00Mar 26, 2024Aspirant
rivadavia Any updates from support on this issue?
I have a WAX615 and am having the same issue. A bummer since I can't return this AP have had it from a while now
- rivadaviaMar 26, 2024Tutor
So after giving support packet dumps, network diagrams, multiple explanations, the level 3 support rep said "Oh yeah we know about that problem, we don't have any plan or estimate of resolution, you should return the access point" So I returned it. Needless to say I won't be considering Netgear for my future networking needs.
