horus66
Jun 01, 2023Aspirant
WAX630EP with EAX15 extender
I recently bought WAX630EP to use as my access point at home. I have a few areas of the house where the signal is not the best so I got EAX15 to patch that up. The access point exposes a few WiFi ne...
schumaku
Jun 04, 2023Guru - Experienced User
horus66 wrote:
I use an iPhone 13 to set up the extender throrugh the Nighthawk app.
Am I doing something wrong? Are these devices incompatible?
In case you are struggling to use the Nighthawk App for successfully configuring the EAX15, I suggest to read the fine documentation https://www.downloads.netgear.com/files/GDC/EAX15/EAX15_UM_EN.pdf and follow the Get Started on p.15 ff. Connect to an existing WiFi network.
