andejo55
Mar 15, 2021Initiate
WBC502 5.8.4.3 Configuration in Progress for over an hour
Just tried applying firmware update 5.8.4.3 to WBC502 via Insight Cloud Portal and it's been sitting at Configuration in Progress for well over an hour. Tried rebooting the device via Cloud Portal ...
schumaku
Mar 15, 2021Guru - Experienced User
Retry by cutting and reapplying the power. To bad these are not standard PoE[+[+]] devices so you could remote power reset at least the locally connected one.
- andejo55Mar 15, 2021Initiate
I reapplied to firmware update but manually through the device directly. This resolved the issue.
