elijahcheung
Feb 17, 2025Follower
WBE750 fan issues
I found that the fan indicator of WBE750 is always 0, and the fan does not run even when the temperature is over 60 degrees Celsius. Is this normal or is it a firmware issue?
mlowe4
Mar 16, 2025Aspirant
I have the same issue I had to drop performance as so to not generate too much heat but close to 57 degrees
