Donone
Apr 15, 2016Aspirant
WC370 wireless AP connection
Is it possible to use a wc370 AP without the prosafe WC7600 wireless controller. I would like to just extend my wired network. Any advice would be great. Thank you
- Apr 17, 2016
Hi Donone,
On behalf of JohnRo, I'm afraid to inform you that the WN370 access point is classified as a Thin Access Point wherein you could only configure and manage it through the WC7600 wireless controller. Therefore, the WN370 cannot be used as a standalone access point. Kindly check this link below for more details:
DaneA
NETGEAR Community Team
Donone
Apr 16, 2016Aspirant
Thanks Johnro for your quick reply. I got the model wrong. I have a WC 370 access point. So is it possible to use the wc370 without the wc7600 wireless control.
Thanks
Thanks
