Donone's avatar
Donone
WC370 wireless AP connection
Is it possible to use a wc370 AP without the prosafe WC7600 wireless controller. I would like to just extend my wired network. Any advice would be great. Thank you
  • DaneA's avatar
    DaneA
    Apr 17, 2016
    Hi Donone,
    On behalf of JohnRo, I'm afraid to inform you that the WN370 access point is classified as a Thin Access Point wherein you could only configure and manage it through the WC7600 wireless controller.  Therefore, the WN370 cannot be used as a standalone access point.  Kindly check this link below for more details:
    WN370 FAQs
    DaneA
    NETGEAR Community Team
ProSupport for Business
