Donone
Apr 15, 2016Aspirant
WC370 wireless AP connection
Is it possible to use a wc370 AP without the prosafe WC7600 wireless controller. I would like to just extend my wired network. Any advice would be great. Thank you
- Apr 17, 2016
Hi Donone,
On behalf of JohnRo, I'm afraid to inform you that the WN370 access point is classified as a Thin Access Point wherein you could only configure and manage it through the WC7600 wireless controller. Therefore, the WN370 cannot be used as a standalone access point. Kindly check this link below for more details:
DaneA
NETGEAR Community Team
Donone
Apr 17, 2016Aspirant
Thank you for replying DaneA. You don't happen to know to it was possible to flash it with we dd-drt?
Cheers for all your help. ;)
DaneA
Apr 17, 2016NETGEAR Employee Retired
Hi Donone,
I have not yet tried using a dd-wrt firmware on a WN370. The WN370 might get bricked if you will flash it with a dd-wrt firmware as well as the warranty will be void.
DaneA
