leleo73
Oct 21, 2019Guide
WC7500 Firmware 6.5.5.18 not valid
Hello,
i tried to upload the new firmware 6.5.5.18 from 6.5.5.0. But it said firmware is not valid. the new firmware 6.5.5.18 is smaller than 6.5.5.0. i think the file from netgear homepage is corrupt.
-> WC7500 wireless controller will not load 6.5.5.18 ... takes about five seconds to locate.
But hey RaghuHR ... something must be wrong!
- leleo73Guide
Hi,
thx for your answer, but what you mean? You will check the firmware?
- RaghuHRNETGEAR Expert
Hi leleo73 How much is the size of the firmware after downloading ? It should be around 225MB.
We downloaded from https://www.netgear.com/support/product/WC7500#Firmware%20Version%206.5.5.18
Found md5 checksum is correct. Could you please double check on this?
Thanks,
Raghu
- leleo73Guide
My file ist 230.419kb is the checksum md5
5BE4B425239CEE41FAAA79D8A9E5FE51
