Tepasquan
Jul 05, 2017Aspirant
WC7500 wireless controller
Hello , This is the gear I have. A WC7500 wireless controller, NETGEAR GS724T v3 ProSAFE 24-port Gigabit Smart Switch, NETGEAR ProSAFE GS510TP 8-Port Gigabit PoE+ Smart Managed Switch with 3 WND930...
- Jul 09, 2017
I just want to follow-up on this. Were you able to access and read the articles I've shared? Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Tepasquan
Jul 10, 2017Aspirant
Hi Dane,
Thanks for the links and the follow up. I have not yet deployed the WC7500. I bench set up the AP's.
I am going to use the Single VLAN configuration similar to the sample but with three APs.
I will have questions as I find out how much I don't know.
Thanks
Tepasquan
