Andreas123
Aug 29, 2019Aspirant
WC7600 Captive Portal and VLAN
I have a WC7600 and 10 Aceesspoints in VLAN 6, IP 10.xx. The guest network is VLAN 5, 192.168.1.xx. Both networks can access the internet, but there is no routing in between. The captive portal is on...
- Sep 04, 2019
Problem solved, it was a misconfigured switch on the way to the access point.
RaghuHR
Aug 30, 2019NETGEAR Expert
Hi Andreas123
Could you please help us to understand your issue with network diagram? Also share your configurations.
Thanks,
Raghu
Andreas123
Sep 04, 2019Aspirant
