knarfer's avatar
knarfer
WC7600 wac720 firmware update failed
I have a problem with the firmware update for the wc7600. i do the update to 6.5.1.8
First i start with the migration firmware because the previous version was 5.5.1.4
3 ap's (wac720) do not receive the migration update, i didn't notice that en do the upgrade to 6.5.1.8.
now there are 3 access points that are in reboot loop.
i try the following:
downgrade the wc7600 to the migration update and connect the ap, ap not updating
remove ap from wc7600, connect with console and try firmware-update-tftp to standalone firmware. after restart still the old firmware.
How can i reset the wac720 to standalone firmware so that i can connect the device to the wc7600?
  • LaxmankumarG's avatar
    LaxmankumarG
    Oct 10, 2017
    Hi,
    Last week our netgear support got in touch with you and resolved the issue for you. Do you want to share any feedback.
  • Retired_Member's avatar
    Retired_Member
    Hi knarfer,
    Welcome to the community. I have sent you a PM regarding this issue. We would like to resolve this for you as quickly as possible.
    Regards
    DavidGo
      LaxmankumarG
      NETGEAR Expert
      Hi,
ProSupport for Business
