lchambers84
Nov 10, 2017Aspirant
WC9500 Controller WAC720 AP Firmware issue
Hello, I am wondering if anyone else has had an issue when after adding a WAC720 AP to the managed list to the WC9500 controller and it applies the firmware update the AP then reboots and get a f...
- Nov 14, 2017
Hi DanA,
Cheers for getting abck to me I think I have fixed the issue now I just wanted to see how it worked throughout yesterday to see if the fix was working and it seems to be. The problem seems to be fixed by adding option vendor 43 and having the vendor ID and IP in hexadecimal format so hopefully all is well.
Thanks for your response.
lchambers84
Nov 14, 2017Aspirant
Hi DanA,
DaneA
Nov 14, 2017NETGEAR Employee Retired
Thanks for the update. I'm happy to know that you were able to fix the problem and share the solution you did. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
