Cofran268
Mar 19, 2024Tutor
we could not verify the certificate: reason = untrusted
Hello, Since 2 months, I'm not able to acces to my WAX. On windows, Edge and Firefox return that message: "we could not verify the certificate: reason = untrusted" without the possibility to pas...
- Mar 26, 2024
I finally found. It comes from Windows wireless setting. I switched from public to private setting and it's now ok!
Sorry for the picture in french
schumaku
Mar 20, 2024Guru - Experienced User
Cofran268 wrote:
On windows, Edge and Firefox return that message: "we could not verify the certificate: reason = untrusted" without the possibility to pass thrue.
It's a self-signed certificate, (generated and?) loaded during the initial device installation.
In general, any browser does allow to accept (I don't say trust or the like) a self-signed certificate. The only exception might be with Enterprise-managed or -operated systems explicitly allowing correct PKI-signed certificates or similar.
Cofran268 wrote:
I never change or set certificate.
As of writing, Netgear does not offer the ability to update or replace the certificate and private key on the WAX6xx nor on the WAC5xx.
