Cofran268
Mar 19, 2024Tutor
we could not verify the certificate: reason = untrusted
Hello, Since 2 months, I'm not able to acces to my WAX. On windows, Edge and Firefox return that message: "we could not verify the certificate: reason = untrusted" without the possibility to pas...
- Mar 26, 2024
I finally found. It comes from Windows wireless setting. I switched from public to private setting and it's now ok!
Sorry for the picture in french
SaHi
Mar 20, 2024Aspirant
Hi,
I have the same issue.
Additionally:
It happens on one device (PC) and on all browsers (Firefox, Edge, Chrome). On my laptop I still can access the router. As said by Cofran268 it's a simple text message without the possibility to pass through. Tried IP of the router as well as routerlogin.net or orbilogin.com. Router is working fine, just cannot access the router settings on my pc.
schumaku
Mar 20, 2024Guru - Experienced User
This tells me that that one device has some enterprise or business policies in place very likely.
Netgear used to distribute private keys and PKI signed (Entrust) certificates with each device. Needless to say, this was a major security risk, because all or series from similar models came with the exact same private key (and cert).
