vickyd48's avatar
vickyd48
Follower
May 02, 2018
Which AP should I get
What is the best AP for the following configuratio?
WAN - IP is not really public, but has access to our Internal LAN and Internet
LAN - IP's will be provided by DHCP or static but differnt subnet that can't access our internal LAN in no shape or form.
Can I use one-to-one NAT to allow devices on WAN side of IP's to reach LAN devices if they are setup with NAT?  Typically the addresses would be public to private NAT, but this is a not doable.  This wouldn't be a question if the IP's were public, but I believe I might have an issue.  Anway what is the best AP I could try this configuration on?
  • Hi vickyd48,
    Welcome to the community! :)
    You may want to check the WAC510 - Insight Managed Smart Cloud Wireless Access Point.  The WAC510 can function either as AP mode or Router mode.  If AP mode is selected, it functions as a standalone access point.  If the Router mode is selected, it functions as a standalone AP with its router functionality enabled including network address translation (NAT) and the option to enable and configure the DHCP server of the access point.  Kindly read page 114 of the WAC510 user manual here.
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi vickyd48,
    DaneA
No content to show
ProSupport for Business
