mammentorp
Feb 17, 2022Tutor
WIFI local network connectivity issues
I have a WAC 124 installed in router mode, connected to a Netgear cable modem. Installation went smoothly, and access to the internet works well for all WIFI connected devices. The problem I have i...
schumaku
Feb 17, 2022Guru - Experienced User
Reads like the SSID is configured with Wireless Isolation enabled.
Check https://www.downloads.netgear.com/files/GDC/WAC124/WAC124_UM_NEW_EN.pdf p.67 "Manage client isolation for a single WiFi
network" FMI
- mammentorpFeb 18, 2022Tutor
Yes!! That was it - client isolation was turned on by default on Wireless Network 2, which was the one I was using. Thank you so much for the tip!
