MAA
Dec 06, 2016Aspirant
Wifi problem
Dears, We are facing a problem with Access point Wifi, when we turning the Acess on after we connect it to the laptop, the Wifi led still turn off. We made reset for the Access device many times an...
- Dec 14, 2016
MAA,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
MAA
Dec 08, 2016Aspirant
Thank you, I will do what you suggest me.
Regards
DaneA
Dec 14, 2016NETGEAR Employee Retired
MAA,
DaneA
