dabacertia
Dec 13, 2017Aspirant
Wifi trunk (before sale question)
Hello, Is it possible to establish a wifi trunk of this kind (A or B)? A. + AP in client mode receives different SSIDs and tag them on the nic - Advantage: the AP that "send signal" can send ...
- Dec 15, 2017
Hi dabacertia,
Welcome to our community!
It is easier to use the first option that you have. You just need to set the port on trunk where the AP is connected so that it can also broadcast the other VLANs. It will still be depending on the AP you are going to use if it supports VLAN.
dabacertia
... the B visio in attach
JohnC_V
Dec 15, 2017NETGEAR Employee Retired
Hi dabacertia,
- dabacertiaDec 16, 2017Aspirant
Hello John,
Thanks for your answer, I will give it a try. I don't know why I thought it needed special feature to transport a trunk through an wireless network/SSID. It is so simple I did not tried it.
Have a nice day
- JohnC_VDec 18, 2017NETGEAR Employee Retired
dabacertia,
Setting up a Trunk to the AP is only applied if you do have multiple SSIDs. If none, no need to configure trunk on it.
- dabacertiaDec 18, 2017Aspirant
Thanks! (a lot) I took good note.
