H-town-Ken's avatar
H-town-Ken
Windows PCs do not see WiFi Network
I recently installed a new WiFi network.  Apple phones, Mac PCs, Samsung Android phones all can see and access the network (some at 802.11ax, others at 802.11ac).
Unfortunately, none of my Windows PCs can see, nor access, the new WiFi network.
WiFi Access Points:  WAX630E (3 total APs)
No VLANS, QoS, nor any filtering above and beyond what comes out of the box. (but I would like to separate and prioritize traffic eventually).
Any idea of why all other OSs seem to be able to see and access WiFi but not Windows?
TIA
  • schumaku's avatar
    schumaku
    Not really an OS question - much more one could guess your Windows PC carry older drivers for some popular hardware (like Intel wireless adapters for example) which isn't able to even recognize, see, or access WiFi 6 802.11ax access points. both the adapter microcode as well as the driver might require an update before you succeed.
    A good point to start is the Intel Driver and Support Assistant https://www.intel.com/content/www/us/en/support/intel-driver-support-assistant.html  ... in case we talk of Inhell adapters for example.
    • H-town-Ken's avatar
      H-town-Ken
      My understanding is that 802.11ax is backward compatible:  I don't need the Windows PCs to be able to use the 6 GHz spectrum, just either the 2.4 GHz and/or 5 GHz frequencies.  It would appear I am missing something.
      • schumaku's avatar
        schumaku
        Scratch this dream for "compatibility". Plenty of Wi-Fi adapters - many Intel ones - especially those with PC-brand driver installations or Windows Update supplied hopelessly outdated drivers don't work at all on 802.11ax. Of course, correct working adapters and systems with  drivers make it compatible.
        This is one of the most popular question or complaint since Wi-Fi6 was introduced. And it never stops - because many users and even pro computer admins operate systems on outdated drivers.
        and no: It's not limited to Windows of course, too.
ProSupport for Business
