kloenie_nl
Sep 15, 2021Aspirant
wireless access point WNDAP360 and new type AP's
hi there, We have 20 WNDAP360's the admin is gone and nobody knows the passwords. Reset it all is not wat we want. we are thinking of buying a new AP make that the main AP and connect the rema...
kloenie_nl
Sep 21, 2021Aspirant
that whas what we tought..
But what new AP can we buy to work with the old AP's ?
i think they need the same Firmware.
but which one can i buy.
Then i buy 2 new ones, let them work together, get a old AP, reset that one, let it work with the new setting and then badabing badaboom :D
JohnC_V
Sep 23, 2021NETGEAR Employee Retired
If the APs are working as standalone, then you can use any AP that you want. I suggest, take a look at our AP selector to find out which AP is suited for your needs.
John
NETGEAR Community Team
