Danielhainich
Feb 16, 2018Aspirant
WNDAP360 VLAN
Hello,
i have WNDAP360 configured as Access-Point with Multi-SSID. I only found option to tag the SSID into one VLAN. What i have to do, to configure multiple tagged VLANs over a SSID? At the other Side, there is an CPE (TPLINK) in ClientMode. The Goal is, to carry 2 tagged VLANS over WLAN to the other Side.
- Ensure both APs are in LoS (Line of Sight) since you are trying on 5 GHz radio. If yes and still if you see an issue we may have to do remote debugging. Let us know.
- DaneANETGEAR Employee Retired
Hi Danielhainich,
Welcome to the community! :)
There is really no option to tag 2 or more VLANs to one SSID. This is not a limitation, thus, this is by design. I suggest you to create another SSID then tag it to another VLAN. The ratio would be ► 1 VLAN : 1 SSID.
DaneA
NETGEAR Community Team
- DanielhainichAspirant
Hi,
and what about the Bridge-Mode? A Bridge should do that, by design. But Documentation for BridgeMode with AP360 is very bad.
Is it possible to build an transparent Wireless Ethernet Bridge with AP360 as Root-Bridge?
The ProSAFE Dual Band Wireless-N Access Point WNDAP360 Reference Manual does clearly document on how to configure Configure Wireless Bridging on p.89 ff. including a Point-to-Point Wireless Network for the point-to-point bridge mode conneciton of two generic LAN segments.
No practical experience if the for 802.1q VLAN TPID Bytes are correctly bridged between the segments - unlikley the AP does interfere with these additonal bytes. Only testing will tell.Good advise is to use the same or very similar similar products for participating in WDS bridges. Interoperability issues are predictable otherwise.
