Danielhainich
Feb 16, 2018Aspirant
WNDAP360 VLAN
Hello, i have WNDAP360 configured as Access-Point with Multi-SSID. I only found option to tag the SSID into one VLAN. What i have to do, to configure multiple tagged VLANs over a SSID? At the oth...
- Mar 14, 2018Ensure both APs are in LoS (Line of Sight) since you are trying on 5 GHz radio. If yes and still if you see an issue we may have to do remote debugging. Let us know.
Danielhainich
Mar 09, 2018Aspirant
yes, bridge ist enabled on both radios. i have tested it with only 5ghz-radio, but its the same result.
RaghuHR
Mar 14, 2018NETGEAR Expert
- DanielhainichMar 14, 2018Aspirant
Hi,
thanks for our help. i had both AP´s in LoS. they did not bridge on 5ghz radio. for now i bridge on 2,4ghz radio. maybe you can help with my DHCP-Problem and this bridge.
thanks
daniel
