Danielhainich
Feb 16, 2018Aspirant
WNDAP360 VLAN
Hello, i have WNDAP360 configured as Access-Point with Multi-SSID. I only found option to tag the SSID into one VLAN. What i have to do, to configure multiple tagged VLANs over a SSID? At the oth...
- Mar 14, 2018Ensure both APs are in LoS (Line of Sight) since you are trying on 5 GHz radio. If yes and still if you see an issue we may have to do remote debugging. Let us know.
DaneA
Feb 18, 2018NETGEAR Employee Retired
Hi Danielhainich,
Welcome to the community! :)
There is really no option to tag 2 or more VLANs to one SSID. This is not a limitation, thus, this is by design. I suggest you to create another SSID then tag it to another VLAN. The ratio would be ► 1 VLAN : 1 SSID.
DaneA
NETGEAR Community Team
