craigpat93
Apr 14, 2022Aspirant
wndap660 two lans?
I have recently purchased a wndap660 which says it is multiple input multiple output. it has two lan ports, i was hoping i could run two Lans via different wifi networks. is this achievable? if ...
Apr 14, 2022Guru - Experienced User
I would review the online user manual information regarding this to see if this is supported.
craigpat93
hey,
I did, and I couldn't see a lot about the reason for it having 2 lan ports.
it just says all can be used to connect. dont know if its to use to send back out to wired devices, as a backup, or for second networks.
thats why I've come to here 🙂
- FURRYe38Apr 14, 2022Guru - Experienced User
I don't have one of these though sometimes having a extra LAN port on the back just means you can connect up an extra device like a PC or laptop or probably daisy chain these with another AP down the line if they were to be ethernet connected. If you don't see any references to separate networks or dual lans, then probably something that's not supported.
