craigpat93
Apr 14, 2022Aspirant
wndap660 two lans?
I have recently purchased a wndap660 which says it is multiple input multiple output. it has two lan ports, i was hoping i could run two Lans via different wifi networks. is this achievable? if ...
Apr 14, 2022Guru - Experienced User
is this achievable? if so could someone point me in the right direction to do this as i cannot seem to find those options to assign networks to certain lan
thanks!
The multiple input/mulitple output (mimo) is a wireless spec to increase throughput.
https://en.wikipedia.org/wiki/MIMO
Not for connecting to different wireless networks and assigning them to different lans.
what you're trying to accomplish isn't possible with that device.
