LaurentG's avatar
LaurentG
nighthawk M1 wrong DNS for Guest network ?bug?
Hi,
I have the following lan setup for my router:
IP 172.102.4.1/24
DNS 172.102.4.253
DHCP enabled
When devices connect to 2.4 or 5 GHz WiFi they get the correct IP and DNS.
When devices connect to Guest network they receive a correct IP but a wrong DNS: They receive 172.102.4.1 and not the 172.102.4.253 as expected.
Is there a workaround to this?
BR,
Laurent.
  • Dear Customer,
    You have contacted the German-speaking NETGEAR Community.
    We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
    Kind Regards,
    DamianM
    NETGEAR Community
1 Reply
  • DamianM's avatar
    DamianM
    NETGEAR Moderator
    Dear Customer,
    Kind Regards,
    DamianM
    NETGEAR Community
