ChristopherG
May 31, 2021Aspirant
I too, have a VLAN routing Problem
Hello,
I would like to segment our network with our new M4300 switch. (At the moment everthing runs in one subnet (VLAN 1))
I created all the VLANs + der IP Interfaces, enabled routing and created a default route to our FW (192.168.175.254)
Now i can route out of any VLAN and also got the DHCP Relay to work, but i somehow cannot route into any VLAN for example VLAN 650.
When i login to the Web GUI i can ping my NIC 192.168.64.21(VLAN 650, int 1/0/24) from Source None, Interface VLAN 650, but not from any other VLAN Interface
But i can ping the VLAN Interface 192.168.64.1 from any other VLAN Interface.
Int 1/0/24 is in General mode, AccessVlanID: 650, Native VLANID:650, PVID:650 and has untagged VLAN 650 membership
How can i fix this? Did i miss some routing setting?
Kind regards
show ip interface brief:
Spoiler
(M4300-12X12F) >show ip interface brief Interface State IP Address IP Mask TYPE Method ----------- ----- --------------- --------------- --------------- --------------- vlan 1 Up 192.168.168.1 255.255.248.0 Primary Manual vlan 80 Up 192.168.7.1 255.255.255.0 Primary Manual vlan 90 Up 192.168.8.1 255.255.255.0 Primary Manual vlan 100 Up 192.168.9.1 255.255.255.0 Primary Manual vlan 130 Up 192.168.12.1 255.255.255.0 Primary Manual vlan 170 Up 192.168.16.1 255.255.255.0 Primary Manual vlan 180 Up 192.168.17.1 255.255.255.0 Primary Manual vlan 190 Up 192.168.18.1 255.255.255.0 Primary Manual vlan 200 Up 192.168.19.1 255.255.255.0 Primary Manual vlan 210 Up 192.168.20.1 255.255.255.0 Primary Manual vlan 220 Up 192.168.21.1 255.255.255.0 Primary Manual vlan 450 Up 192.168.44.1 255.255.255.0 Primary Manual vlan 460 Up 192.168.45.1 255.255.255.0 Primary Manual vlan 470 Up 192.168.46.1 255.255.255.0 Primary Manual vlan 650 Up 192.168.64.1 255.255.254.0 Primary Manual vlan 660 Up 192.168.66.1 255.255.254.0 Primary Manual vlan 670 Up 192.168.68.1 255.255.254.0 Primary Manual vlan 680 Up 192.168.70.1 255.255.254.0 Primary Manual vlan 690 Up 192.168.72.1 255.255.254.0 Primary Manual vlan 700 Up 192.168.74.1 255.255.254.0 Primary Manual vlan 800 Up 192.168.94.1 255.255.254.0 Primary Manual vlan 810 Up 192.168.96.1 255.255.254.0 Primary Manual vlan 820 Up 192.168.98.1 255.255.254.0 Primary Manual vlan 830 Up 192.168.100.1 255.255.254.0 Primary Manual vlan 840 Up 192.168.102.1 255.255.254.0 Primary Manual
show ip route:
Spoiler
(M4300-12X12F) >show ip route
Route Codes: C - Connected, S - Static
R - RIP Derived
O - OSPF Derived, IA - OSPF Inter Area
E1 - OSPF External Type 1, E2 - OSPF External Type 2
N1 - OSPF NSSA External Type 1, N2 - OSPF NSSA External Type 2
K - Kernel, P - Net Prototype
Default Gateway(s): 192.168.175.254
S 0.0.0.0/0 [1/0] via 192.168.175.254, 03d:00h:39m, vlan 1
C 192.168.7.0/24 [0/0] directly connected, vlan 80
C 192.168.8.0/24 [0/0] directly connected, vlan 90
C 192.168.9.0/24 [0/0] directly connected, vlan 100
C 192.168.12.0/24 [0/0] directly connected, vlan 130
C 192.168.16.0/24 [0/0] directly connected, vlan 170
C 192.168.17.0/24 [0/0] directly connected, vlan 180
C 192.168.18.0/24 [0/0] directly connected, vlan 190
C 192.168.19.0/24 [0/0] directly connected, vlan 200
C 192.168.20.0/24 [0/0] directly connected, vlan 210
C 192.168.21.0/24 [0/0] directly connected, vlan 220
C 192.168.44.0/24 [0/0] directly connected, vlan 450
C 192.168.45.0/24 [0/0] directly connected, vlan 460
C 192.168.46.0/24 [0/0] directly connected, vlan 470
C 192.168.64.0/23 [0/0] directly connected, vlan 650
C 192.168.66.0/23 [0/0] directly connected, vlan 660
C 192.168.68.0/23 [0/0] directly connected, vlan 670
C 192.168.70.0/23 [0/0] directly connected, vlan 680
C 192.168.72.0/23 [0/0] directly connected, vlan 690
C 192.168.74.0/23 [0/0] directly connected, vlan 700
C 192.168.94.0/23 [0/0] directly connected, vlan 800
C 192.168.96.0/23 [0/0] directly connected, vlan 810
C 192.168.98.0/23 [0/0] directly connected, vlan 820
C 192.168.100.0/23 [0/0] directly connected, vlan 830
C 192.168.102.0/23 [0/0] directly connected, vlan 840
C 192.168.168.0/21 [0/0] directly connected, vlan 1
- DamianMNETGEAR Moderator
Dear Customer,
You have contacted the German-speaking NETGEAR Community.
We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
Kind Regards,
DamianM
NETGEAR Community- ChristopherGAspirant
Hallo DamianM
Ja das Problem bzw eine Lösung habe ich leider noch nicht gefunden.
Dies ist auch (leider) das erste mal dass ich einen L3 Switch mit Routing konfiguriere (bisher habe ich nur L2+ Router on a Stick verwendet).
Dem Benutzerhandbuch nach sollte jedoch alles richtig eingestellt sein.
Ich kann auf jedem virtuellen Interface(inter-VLAN) die GUI des Switches erreichen, jedoch kann ich meine physisch direkt an den Port verbundene NIC nicht erreichen. ARP Eintrag ist da und VLAN Zugehörigkeit stimmt und die Route für das VLAN wurde ja auch automatisch erzeugt nachdem ich das Interface erstellt habe.
Den VLAN-Static-Routing-Wizard benötige ich ja in diesem Fall eh nicht oder?Viele Grüße
Hallo ChristopherG,
Könntest Du mir Dein Netzwerk gräfisch mit allen VLANs und Modellbezeichnungen darstellen?
Freundliche Grüße,
DamianM
NETGEAR Team
Machen Sie mit!
ProSupport for Business
