tYin
May 12, 2022Aspirant
Power Control for POE Slot MS510TX
hello together, i use the MS510TX to connect the 2 POE industrie camera " to build a reference system. the camera were powered by the POE Port of MS510TX. To control the temperature of came...
- May 13, 2022
Dear Customer,
You have contacted the German-speaking NETGEAR Community.
We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
Kind Regards,
DamianM
NETGEAR Community
DamianM
May 13, 2022NETGEAR Moderator
Dear Customer,
Kind Regards,
DamianM
NETGEAR Community
tYin
May 13, 2022Aspirant
Danke für den Hinweis, dann schreibe ich meine Frage neu auf Deutsch!
- DamianMMay 13, 2022NETGEAR Moderator
Hallo @tYin,
Du kannst Deine Frage auch unter diesem Thread verfassen und brauchst keinen neuen zu öffnen.
Freundliche Grüße,
DamianM
NETGEAR Team
Machen Sie mit!
ProSupport for Business
