ktrojok's avatar
ktrojok
switch managament ip accessible on specific vlan
Hi,
I am trying to set a management ip for my stack:
ip management vlan 30 10.10.30.70 255.255.255.0
ip management source-interface vlan 30
interface vlan 30
routing
ip address 10.10.30.70 255.255.255.0
Result:
(M4300-52G) (Config)#show ip management
IPv4 Interface Status.......................... Up
IPv4 Management Interface...................... vlan 30
IP Address..................................... 10.10.30.70
Subnet Mask.................................... 255.255.255.0
Method......................................... Manual
Routing Mode................................... Enable
Default Gateway................................ 0.0.0.0
Source Interface............................... vlan 30
Burned In MAC Address.......................... 34:98:B5:97:84:12
Locally Administered MAC address............... 00:00:00:00:00:00
MAC Address Type............................... Burned In
Then I set a couple of ports to be mode access to the desired VLAN:
interface 1/0/1
switchport mode access
switchport access vlan 30
When connecting to this switchport with a corresponding ip address, I am unable to ping or access the switch.
kind regards
Konrad
  • .. well, I was missing to set the default gateway for the VLAN resp. the management interface. I can't find a command line to set a gateway information for a VLAN ip interface ..
    kind regards
    Konrad
1 Reply
    kind regards
    Konrad
Machen Sie mit!
ProSupport for Business
Mehr erfahren
