boards
Feb 09, 2022Aspirant
GS110EMX 10GB-LAN connection
Hello there, I am no techie, and in these days and esp. in this city it is complicated to get a good admin to handle what I am about to ask you. Nothing special I guess but, as I said, I am no techi...
schumaku
Feb 09, 2022Guru - Experienced User
Don't esablish any other network connection on your windows PC - only the 10 GbE link to the GS110EMX, from where you can reach the NAS2 on the other 10 GbE GS110EMX port, and the rest of your network on the 1 GbE ports, with one link to the router.
- boardsFeb 10, 2022Aspirant
Hi Schumaku,
that's what I did.
GS110EMX
Port 1: Router
Port 2: Printer
Port 3: NAS1
Port 9: PC (Cat 6a)
Port 10: NAS2 (Cat 6)
But 10Gb between PC and NAS2 is not established, it is still 1Gb LAN.
Does it downgrade to 1Gb automatically? What could be the problem?
Lmk
thx
Alex
- schumakuFeb 10, 2022Guru - Experienced User
boards wrote:
Port 9: PC (Cat 6a)
The Ethernet links are negotiated established between the PC adapter, and the switch port, and the NAS2 and the switch port. If one of the links does run on a lower speed, of course the connection speed is limited to the slowest link.
Troubleshooting does begin with checking the MultiGig port (#9 and #10) LEDs on the GS110EMX, check the PC adapter properties and status, check the Syno 10 GbE adapter, .... always LED indications and information available on the relevant OS.
Machen Sie mit!
ProSupport for Business
