sg08234
Jul 26, 2023Aspirant
VLAN on Netgear GS324TP
I want to span two different WLANs (based on Ubiquity-APs) both using the guest port of a Fritz!Box for Internet access. Let's say these VLANs have ID 200 and 300. IOn my Netgear GS324TP I defined t...
sg08234
Thanks for explanation! This is exactly what I understood.
But concerning On the same port, only one VLAN can be carried untagged for the obvious reason. (which I did to span two WLANs on the guest port of the Fritz!Box): This works ( on both WLANs I have Internet access) - so: What are the obvious reasons?
Thanks - Michael
schumaku
Jul 26, 2023Guru - Experienced User
This is not what I had described above. The two physical ports make up different VLANs but implemented as untagged access ports each is fine.
Or do you talk of two SSIDs mapped to two tagged VLAN on the access points mapped to the same physical port? This can't work. The PVID config on the port does define to which VLAN the untagged frames will be assessed ciateed. And this can be only one.
Both the guest and the normal LAN can provide Internet access over the NAT router.
Sho us some screenshots of what you have configured please.
- sg08234Jul 26, 2023Aspirant
Thanks!
I attached my complete configuration. Port 23 is connected to the guest port of the Fritz!Box and VLAN 200 and 300 handle two different WLAN-SSIDs (implemented via Ubiquiti-APs).
I understand that this should not work, but: Devices connected to either of both WLANs have Internet access through port 23 (their IP-address is in the range of the FB guest network [192.168.179.x]).
This in general is what I want/need but I am not sure if this only works by error and if both WLANs are really separated.
Michael
- schumakuJul 27, 2023Guru - Experienced User
Michael,
Ganz kurz in Deutsch, die Anglosachsen werden es uns verzeihen (oder auch nicht).
Mit einer FritzBox: Mir erschliest sich nicht wie, ab einer FritzBox (mit einem LAN und einem Gast-LAN) nicht weniger als vier Netzwerke/VLAN 1,100, 200, 300 reaisiert werden sollten.
Fröhliches Raten: FritzBox LAN Ports (drei oder vier, je nach Modell) hängen auf Port 22 (VLAN 1, untagged), Port 24 (VLAN 100, untagged), vielleicht auch Port 21 (VLAN 1, untagged), und dazu noch das VLAN-mässig fälschlicherweise überbelegte Gast-LAN auf Port 23.
Das Gast-LAN ausschliesslich als eigenes Netzwerk (Subnetz 192.168.179.x/24), als VLAN 200 auf dem Port 23 übernommen werden.
Wenn man dann Wireless Access Points integriert, kann man durchaus auch SSIDs für die vier Netzwerke Default (VLAN 1), Intern (VLAN 100), Gast (VLAN 200) und Kantine (VLAN 300) realisieren - auch wenn 1, 100 und 300 auf dem selben IP Subnetz laufen, und nur das Gast auf 200,
Unbedint aufräumen! Hilft das so mal weiter?
Grüsse aus der Schweiz!
-Kurt
- sg08234Jul 27, 2023Aspirant
Danke aus Berlin in die Schweiz!
Hier noch ein paar Erklärungen:
- VLAN 1 wird nicht genutzt und wird auch nirgends an die FB weitergleitet (ich habe es nut aus Unkenntnis "irgendwie" eingerichtet)
- VLAN 100 ist das interne Netztund wird ganz odnungsgemäß untagged über Port 100 an den Port 1 der FB weitergeleitet
- VLAN 200 und VLAN 300 als Gast-(W)LAN-Netzwerke werden nicht ordnungsgemäß (*) über den Port 23 an den Gast-LAN Port 4 der FB weitergeleitet.
* Google states: "one should never have a port with more than one untagged IDs" and Netgear (this topic) states: Two SSIDs mapped to two tagged VLAN on the access points mapped to the same physical port? This can't work. The PVID config on the port does define to which VLAN the untagged frames will be assessed ciateed. And this can be only one.
Aber es funktioniert: Endgeräte, die sich an einem der beiden Gast-WLANs anmelden, bekommen Internet und sind im Gast-LAN (192.168.179.x) der FB. This in general is what I want/need but I am not sure if this only works by error and if both WLANs are really separated.
Was kann / soll ich wie aufräumen, um mein vorgenanntes Ziel (zwei per VLAN getrennte Gastnetze nutzen den Gast-Zugang der FB) auch ohne eine nicht ordnungsgemäße Konfiguration zu erreichen? Die Lösung wäre mit Sicherheit (?) ein Multi-VLAN-fähiger Router wie ein LanCom, aber das sind ca. 600,- €.
Michael
Machen Sie mit!
ProSupport for Business
