tibatong
Mar 03, 2019Aspirant
Firmware 2.3.0.28
Mein Orbi hat wie immer gemeldet, dass es keine neue Firmware gibt, aber auf den amerikanischen Netgear-Seiten findet sich dann doch eine neue Firmware mit der Versionsnummer 2.3.0.28. Hat die schon ...
tibatong
Hier mal die Liste der Änderungen/Bug-Fixes:
New Features and Enhancements:
- Adds customer firmware pull.
- Expands the IP reservation function from 64 clients to 253 devices.
- Adds weak admin password checking
Bug Fixes:
- Includes bug fixes for stability when using Ethernet backhaul in large deployments:
- Wireless backhaul might not change to Ethernet backhaul when an Ethernet cable is connected.
- Reduces the time to stabilize topology with Ethernet backhaul
- Reduces the Ethernet backhaul loop that might cause kernel panic
- Includes bug fixes for stability and performance:
- Fixes the LAN/WAN bidirectional throughput on the DHCP mode drop issue.
- Fixes the downstream drop issue when port forwarding is enabled.
- Fixes the issue where some online games periodicity lag.
- Fixes the issue where the PPPOE connection unstable
- Fixes the issue where the client’s connection type does not display correctly on the Attached Devices page:
- Wireless client connection will show as wired
- Client occasionally shows as connected to the wrong satellite
- Fixes multiple IPV6 issues
- Fixes an issue related to the SSID containing special characters
- Fixes the issue where the user sometimes can't register their Orbi Voice
- Fixes the email address issue on the Security Email page
- Updates the DDNS No-IP privacy policy
- Fixes the following security issues:
- Roll-out NETGEAR Q4 PSV items
- [MR2.2][Guest Isolation] The guest client can access the GUI via an IPv6 address
FrankHe
Mar 04, 2019NETGEAR Employee Retired
- tibatongMar 04, 2019Aspirant
Ich habe ein RBK40-System, das ich um einen RBS20 erweitert habe. Für beide ist die neue Firmware verfühbar. Bisher betreibe ich die Kombi mit Version 2.2.1.210. Ich frage mich nur, warum die Firmware-Update-Funktion noch nie eine neue Version gefunden hat. Das scheint eine reine Placebo-Funktion zu sein.
