mschnrm
Jun 23, 2022Aspirant
R6400v2 updated nicht mehr
Habe mehrmals versucht den router ueber die app nach updates suchen zu lassen, es kommt jedesmal “fehler bei firmware ueberpruefung”, auch nach einem router neustart kein erfolg.
Aktuelle FW V1.0.4.106 10.0.80
You can manually update the firmware.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- mschnrmAspirantOk! Thanks, I will try it like that!
- mschnrmAspirantI managed to push the update through routerlogin, it updated successfully.
However, the nighthawk app now has issues connecting to the router, if i manage to establish a connection, it wouldn’t load router settings, keeps freezing with “please be patient”..
