tosmith1's avatar
Jul 26, 2019
Netgear armor
How to remove netgear armor. After installing and activating, my printer started printing pages of ascii characters. Absolutely no faq help
how do I uninstall this piece of SPAM and spyware.
  • Thanks for the heads up, but I had already figured out how to disable the unwanted software.
    I was given no option weather to install or not. What no one can tell me is how to uninstall this add on that will generate more income for netgear and bitdefender who has no info on their site except advertising more products.
    I would appreciate if you would tell netgear NOT to install add on without a way to uninstall.
    • tosmith1's avatar
      tosmith1
      Tutor
