Jacob_of-Aus
Jun 09, 2026Guide
RS600 Shows false negative (Blocked) Devices
For years we have had a network that comprises of a gateway on the ground floor and an Access Point on the 3rd level that connected to the ground floor by cable - we control the access to the Interne...
- Sep 24, 2026
To all that assisted on this thread - Update.
After quite an in depth collaboartion with Netgear support, it looks like our problems are close to be resolved with a pending firmware update to be released by Netgear. We have a beta version of that update that we are testing and it largely behaves as we expect.
We are told that the the release of the full update is a matter of few weeks.
Thank you all for you help and thank Netgear Support for their prompt action.Jacob
Jun 10, 2026Guru - Experienced User
FYI, you posted this in the ReadyNAS forum. I moved it for you.
No idea if this will help, but you could try the release candidate firmware here:
- https://community.netgear.com/discussions/en-home-nighthawk-rs300-beta-firmware/rs600-release-candidate-firmware-v1-2-7-2/2478731
