rs600
1 TopicRS600 Shows false negative (Blocked) Devices
For years we have had a network that comprises of a gateway on the ground floor and an Access Point on the 3rd level that connected to the ground floor by cable - we control the access to the Internet by an Access Control List (ACL). The total devices connected to the network is 40, give or take. The last configuration (before the current one was RAX50 as the gateway and RAX40 as the access point. All was good until last February. In February we bought an RS600, installed it as the gateway and changed the RAX50 to the Access Point (replacing the RAX40) when all our problem started. We have found that older devices basically work fine but newer ones such as iPhone 16 & 17, iPad 11, recent Windows 11 and newer Android devices are giving us grief, particularly those connected to the network via the Access Point. The problem manifests itself that such devices that are connected to the Access Point, show on the ACL as connected to gateway (which holds the ACL for the whole house) and "Blocked". Repeated attempts to "Allow" them come back as "Blocked". But what is weird is that when we look at "Attached Devices" list of the RS600 those "blocked" devices show as connected by wire (i.e. coming from the Access Point" and "Allowed" and may have Internet (but not always). The only real blocked devices (MAC address is not on the ACL) are shown correctly as "Blocked" on the Connected Devices" list. Just to make sure that the problem does not come from the Access Point, we put the RAX40 back as Access Point and got the same behaviour. Sometimes (but not always) we can resolve the problem by turning the affected devoices off, remove their MAC address from the ACL and then adding them back manually to the list of "allows devices not connected" list. Talking to Netgear support did not produce any meaningful relief. The RS600 firmware version is V1.0.6.22. I am interested to find out if anyone else has the problem or if there is a solution to it. Thank you.Solved636Views0likes26Comments
