Jacob_of-Aus
Jun 09, 2026Guide
RS600 Shows false negative (Blocked) Devices
For years we have had a network that comprises of a gateway on the ground floor and an Access Point on the 3rd level that connected to the ground floor by cable - we control the access to the Interne...
- Sep 24, 2026
To all that assisted on this thread - Update.
After quite an in depth collaboartion with Netgear support, it looks like our problems are close to be resolved with a pending firmware update to be released by Netgear. We have a beta version of that update that we are testing and it largely behaves as we expect.
We are told that the the release of the full update is a matter of few weeks.
Thank you all for you help and thank Netgear Support for their prompt action.Jacob
schumaku
Jun 10, 2026Guru - Experienced User
Jacob_of-Aus wrote:But what is weird is that when we look at "Attached Devices" list of the RS600 those "blocked" devices show as connected by wire (i.e. coming from the Access Point" ...
Looking from the RS600, devices associated (wireless) to the RAX40 Access Point - these become wired connections, from the RS600 LAN side of course.
Jacob_of-Aus wrote:older devices basically work fine but newer ones such as iPhone 16 & 17, iPad 11, recent Windows 11 and newer Android devices are giving us grief, particularly those connected to the network via the Access Point.
All these newer systems default to using Randomized MAC addresses - Apple misleadingly names this feature Private Wi-Fi Address - unless you explicitly switch to use the effective (physical) device MAC address.
Jacob_of-Aus wrote:we control the access to the Internet by an Access Control List (ACL).
MAC address randomization is a privacy feature used by modern devices (like phones and laptops). It hides your physical, factory-assigned MAC address by using fake, temporary addresses when connecting to Wi-Fi. Using this feature on your own managed network, does not make any sense - it's just causing issues, like the inability to reserve an IP address for each device on the DHCP server, typically your router - here your RS600. With the wonderful ***** idea of using Access Control List (ACL) - this is not an ACL for the Internet Access, much more an ACL controlling access to your network, wireless or wired - you create all these issues yourself, perfectly hit this situation, shooting into your own knee:
Never configure more security than you can deal with!
It is not a false negative - for the Access Control List (ACL), a device with a different MAC address is a different device.
- StephenBJun 10, 2026Guru - Experienced User
schumaku wrote:
All these newer systems default to using Randomized MAC addressesYes, and this should be turned off for your home network, especially if you have more than one wifi network name.
FWIW, Windows 11 defaults the random hardware addresses setting to "off" on private networks. And normally your home network should be set up as private. So also make sure windows 11 is classifying the home network as "private".
Jacob_of-Aus: if you aren't using parental controls, then you could just disable the ACL. The security benefit is minimal if you are using a good wifi password. One of many articles on the subject is here:
