Jacob_of-Aus's avatar
Jun 09, 2026
RS600 Shows false negative (Blocked) Devices
For years we have had a network that comprises of a gateway on the ground floor and an Access Point on the 3rd level that connected to the ground floor by cable - we control the access to the Interne...
  • Jacob_of-Aus's avatar
    Sep 24, 2026
    To all that assisted on this thread - Update.
    After quite an in depth collaboartion with Netgear support, it looks like our problems are close to be resolved with a pending firmware update to be released by Netgear. We have a beta version of that update that we are testing and it largely behaves as we expect.
    We are told that the the release of the full update is a matter of few weeks.
    Thank you all for you help and thank Netgear Support for their prompt action.
    Jacob
