Jacob_of-Aus
Jun 09, 2026Guide
RS600 Shows false negative (Blocked) Devices
For years we have had a network that comprises of a gateway on the ground floor and an Access Point on the 3rd level that connected to the ground floor by cable - we control the access to the Interne...
- Sep 24, 2026
To all that assisted on this thread - Update.
After quite an in depth collaboartion with Netgear support, it looks like our problems are close to be resolved with a pending firmware update to be released by Netgear. We have a beta version of that update that we are testing and it largely behaves as we expect.
We are told that the the release of the full update is a matter of few weeks.
Thank you all for you help and thank Netgear Support for their prompt action.Jacob
Jacob_of-Aus
Jun 13, 2026Guide
I see that this thread is marked as solved - I certainly did not do it. Unfortunately the problem is far from solved what is the meaning of this phenomena?
schumaku
Jun 15, 2026Guru - Experienced User
Lack of any solution on sight, I had unticked it on your behalf yesterday.
- Jacob_of-AusJun 15, 2026Guide
Thanks Schnaku
