Christian_S
Jul 14, 2025Aspirant
N204 Remove inactive volumes to use the disk. Disk #1,2,3,4. Firmware 6.10.10
Hi all,
I have an RN204 with 4x WD RED NAS 6TB drives installed.
Yesterday around 3 PM, my NAS crashed because I overloaded it (copying large files and running two Time Machine backups simultaneously).
I had to unplug the device to force a reboot. It restarted normally and initially everything seemed fine.
Then a message appeared saying a resync had started. I figured it was due to the crash.
However, after about an hour, the progress was still stuck at 0.00%, and I suspected the NAS had frozen again — so unfortunately, I unplugged it a second time.
That was a big mistake. After the next reboot, another resync message appeared for disks 2 and 4.
Shortly after, I received another message saying both disks had switched from "resync" to "online", which already seemed strange to me.
When I checked the volumes, I found the situation shown in the attached screenshot with the "Remove inactive volumes to use the disk" message.
All disks are listed as "online", but the volumes no longer appear to be mounted.
I already tried removing all disks and booting, as well as booting with only disk 1, or disks 1 and 3, and also without disk 4. Unfortunately, none of these attempts were successful.
Any ideas on how to get the device to recognize the volumes again would be greatly appreciated. I assume it might require connecting to the NAS via SSH and using Linux commands to remount the disks.
I also found this thread, but unfortunately, it doesn’t provide much useful information:
https://community.netgear.com/discussions/readynas-use/rn204-remove-inactive-volumes-to-use-the-disk-disk-1234-firmware-6-10-8/2349047
If needed, I can send the logs from yesterday via private message or cloud storage.
Ich konnte mein Problem zufällig mithilfe von SSH und einigen Befehlen aus dem Forum lösen, wodurch das NAS die Volumes wieder gemountet hat.
Das Thema kann daher geschlossen werden.English:
I was able to solve my issue by chance using SSH and a few commands I found here in the forum. As a result, the NAS has successfully remounted the volumes.
This thread can be closed.
- Christian_SAspirant
This thread can be closed.- tbachneAspirant
Ich habe ein ähnliches Problem. Nachdem ich nach dem Urlaub das System wieder hochgefahren hatte, hatte
ich keinen Zugriff mehr auf die Netzlaufwerke. Also habe ich mich auf der Administratorseite eingeloggt. Hier bekomme ich den Hinweis, ich möge die inaktiven Volumes entfernen.
Im Netz bin ich dann über diesen Thread gestolpert
https://community.netgear.com/discussions/de-readynas-einsatz/rn424-volume-nach-neustart-nicht-mehr-vorhanden/2337953
Was kann ich tun, um das Volume wiederherzustellen und auf die Daten zuzugreifen?
I own a ReadyNas 104, which has worked flawlessly so far. Since I was on
vacation, I shut down the system.
After I restarted the system after my vacation, I no longer had access
to the network drives. So I logged into the administrator page. Here I
get a message telling me to remove the inactive volumes.
I then stumbled across this thread online:
What can I do to restore the volume and access the data?
Machen Sie mit!
ProSupport for Business
