Joschka
Jan 14, 2015Tutor
RN104 OS6.2.2 Spindown funktioniert nicht mehr
Hallo, leider funktioniert bei meinem RN104 mit OS6.2.2 der Festplatten Spindown nicht mehr (das NAS versucht erst garnicht die Festplatten in den spindown zu schicken). Unter OS6.2 und 6.2.1 hat d...
Dorset_tx
Jan 24, 2015Guide
I may be jumping in on the wrong thread as I have had to depend on Google translate, having no German, but am I right in thinking this thread is about the disk spin down functionality not working with 6.2.2?
If so I am experiencing the same problem on a RN102 box. I was running 6.1.9 so disk spin down functionality, upgraded to 6.2.2 as was please to find there was now a disk spin down option. However, it only seems to work intermittently. I cycle my NAS manually as it only gets occasional use, some days the disk spin down works others it doesn't. I have no apps installed, the only active protocols are SMB, UPnP, HTTP, HTTPS. The problem persists even when the only other active device on the network are the 5 port switch and the router. It also persist with the network cable removed.
I have also had the very occasional problem with the box switching itself on for no apparent rhyme or reason, this has been ongoing since I purchased it and independent of firmware version. I suspect it may be being cause by momentary interruptions to the utility supply as I don't currently use a UPS.
Richard.
Richard.
Machen Sie mit!
ProSupport for Business
