-MeTRiX-
Feb 03, 2016Aspirant
RN204: Raid-X / Flex-Raid 5 mit Verschlüsselung keine volle Kapizität?
Hallo zusammen, mein RN204 ist wie folgt mit Platten ausgestattet: 2x 4TB 1x 3TB 1x 2TB Laut http://rdconfigurator.netgear.com/raid/index.html müsste sowohl bei X-Raid wie auch Flex-Raid: R...
JennC
Feb 04, 2016NETGEAR Employee Retired
Hello -Metrix-,
Welcome to the community!
Can you please post a screenshot of the admin page's Volumes? Please also let us know the current FW version.
-MeTRiX-
Feb 04, 2016Aspirant
Sure, I'm using the current version 6.4.1 and I expected to get a single VOLUME with a total of 8 TB instead of 5.44 (traditional Raid 5 as you can see here):
https://www.dropbox.com/s/kpv2nj5cfbvwbdc/Unbenannt.PNG?dl=0
Hope you can give me a short answer if it's not possible from technical side to have it as a single volume or it's a technical problem.
- mdgm-ntgrFeb 05, 2016NETGEAR Employee Retired
Are you using encryption?
Machen Sie mit!
ProSupport for Business
