LC342
Apr 25, 2023Aspirant
CAX30 - Getting t3 and t4 Timeouts constantly .
I have an xfinity 800 mbps plan. Keep getting T3 T4 timeouts Looks like looking for channel 2 - 3 -4 The only upstream channels that are locked are 1 and 5 . Have Firmware v1.4.12.2 Do i need more upstream channels? Getting 756.79 download and 23.78 upload - wired 149.00 down and 23.8 up wifi. just keep getting dropouts and/or delays on wifi I beleive due to all the t3-t4 timeouts. ??????suggestions.
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 1 | 2560 Ksym/sec | 35600000 Hz | 42.5 dBmV |
| 2 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0 dBmV |
| 3 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0 dBmV |
| 4 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0 dBmV |
| 5 | Locked | ATDMA | 5 | 2560 Ksym/sec | 40400000 Hz | 39.5 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0 dBmV |
| 2023-04-25 07:39:46 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; |
| 2023-04-25 07:39:45 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; |
| 2023-04-25 07:39:45 | Critical (3) | Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; |
| 2023-04-25 07:37:17 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; |
| 2023-04-25 07:37:15 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; |
| 2023-04-25 07:37:15 | Critical (3) | Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; |
| 2023-04-25 07:37:09 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; |
| 2023-04-25 07:37:07 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; |
| 2023-04-25 07:37:07 | Critical (3) | Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; |
Please post a copy and paste of the modems FULLL connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- LC342Aspirant
Version 1.4.12.2
Cable ConnectionCancel ApplyFrequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency <tabindex=-1>Startup Procedure</tabindex=-1> Procedure Status Comment Acquire Downstream Channel 549000000 Hz Locked Connectivity State OK Registration Complete Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD IPv6 only <tabindex=-1>Downstream Bonded Channels</tabindex=-1> Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectabables 1 Locked 256 QAM 9 549000000 Hz 1.4 dBmV 40.0 dB 0 0 2 Locked 256 QAM 1 495000000 Hz 1.7 dBmV 40.0 dB 0 0 3 Locked 256 QAM 2 507000000 Hz 1.6 dBmV 39.9 dB 0 0 4 Locked 256 QAM 3 513000000 Hz 1.6 dBmV 40.0 dB 0 0 5 Locked 256 QAM 4 519000000 Hz 1.6 dBmV 40.0 dB 0 0 6 Locked 256 QAM 5 525000000 Hz 1.6 dBmV 40.0 dB 0 0 7 Locked 256 QAM 6 531000000 Hz 1.6 dBmV 40.1 dB 0 0 8 Locked 256 QAM 7 537000000 Hz 1.5 dBmV 40.0 dB 0 0 9 Locked 256 QAM 8 543000000 Hz 1.5 dBmV 40.0 dB 0 0 10 Locked 256 QAM 10 555000000 Hz 1.3 dBmV 40.0 dB 0 0 11 Locked 256 QAM 11 561000000 Hz 1.3 dBmV 40.0 dB 0 0 12 Locked 256 QAM 12 567000000 Hz 1.1 dBmV 39.9 dB 0 0 13 Locked 256 QAM 13 573000000 Hz 1.0 dBmV 39.9 dB 0 0 14 Locked 256 QAM 14 579000000 Hz 1.0 dBmV 39.9 dB 0 0 15 Locked 256 QAM 15 585000000 Hz 0.8 dBmV 39.8 dB 0 0 16 Locked 256 QAM 16 591000000 Hz 0.8 dBmV 39.8 dB 0 0 17 Locked 256 QAM 17 597000000 Hz 0.7 dBmV 39.7 dB 0 0 18 Locked 256 QAM 18 603000000 Hz 0.6 dBmV 39.6 dB 0 0 19 Locked 256 QAM 19 609000000 Hz 0.4 dBmV 39.6 dB 0 0 20 Locked 256 QAM 20 615000000 Hz 0.2 dBmV 39.5 dB 0 0 21 Locked 256 QAM 21 621000000 Hz 0.3 dBmV 39.5 dB 0 0 22 Locked 256 QAM 22 627000000 Hz 0.0 dBmV 39.3 dB 0 0 23 Locked 256 QAM 23 633000000 Hz 0.0 dBmV 39.4 dB 0 0 24 Locked 256 QAM 38 447000000 Hz 2.0 dBmV 40.2 dB 0 0 25 Locked 256 QAM 39 453000000 Hz 1.9 dBmV 40.2 dB 0 0 26 Locked 256 QAM 40 459000000 Hz 1.8 dBmV 40.0 dB 0 0 27 Locked 256 QAM 41 465000000 Hz 1.8 dBmV 40.1 dB 0 0 28 Locked 256 QAM 42 471000000 Hz 1.7 dBmV 40.0 dB 0 0 29 Locked 256 QAM 43 477000000 Hz 1.8 dBmV 40.0 dB 0 0 30 Locked 256 QAM 44 483000000 Hz 1.8 dBmV 40.1 dB 0 0 31 Locked 256 QAM 45 489000000 Hz 1.7 dBmV 40.0 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 <tabindex=-1>Upstream Bonded Channels</tabindex=-1> Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 2560 Ksym/sec 35600000 Hz 42.8 dBmV 2 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 3 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 4 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 5 Locked ATDMA 5 2560 Ksym/sec 40400000 Hz 39.5 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV <tabindex=-1>Downstream OFDM Channels</tabindex=-1> Channel Channel ID Indicator Subcarrier Zero Frequency Active Subcarrier Number Range Total Codewords Uncorrectable Codewords 1 37 Non-Primary 659.6 MHz 1108 ~ 2987 140037691 0 2 0 Other 0 MHz 0 ~ 0 0 0 <tabindex=-1>Upstream OFDMA Channels</tabindex=-1> Channel UpstreamIsMuted Ranging Status Subcarrier Zero Frequency Active Subcarrier Number Range Symbols Per Frame Tx Power 1 Other 0 MHz 0 ~ 0 0 0 dBmV 2 Other 0 MHz 0 ~ 0 0 0 dBmV Extended Upstream Transmit Power Enable Extended Upstream Transmit Power Current System Time: 2023-04-25 09:11:25System Up Time: 11:14:42 - LC342AspirantSorry forgot event logEvent LogClear Log Refresh
Time Priority Description 2023-04-25 08:16:46 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:16:45 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:16:45 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:16:27 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:16:26 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:16:26 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:15:48 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:15:46 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:15:46 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:11:33 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:11:32 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:11:31 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:10:17 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:10:16 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:10:16 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:09:03 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:09:01 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:09:01 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:06:01 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:05:59 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:05:59 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:04:13 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:04:12 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:04:12 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:03:38 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:03:36 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:03:36 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:01:13 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:01:11 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 08:01:11 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 07:59:19 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 07:59:18 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 07:59:18 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 07:56:34 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 07:56:33 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 07:56:33 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 07:56:21 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 07:56:20 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 07:56:20 Critical (3) Ranging Request Retries exhausted;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; 2023-04-25 07:53:05 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:8a:69:54;CMTS-MAC=00:01:5c:68:a2:92;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Guru - Experienced User
Power levels and Correctables and such are good.
However many Criticals are being logged that the ISP needs to review and resolve. Any Errors or Warnings should also be reviewed by the ISP.
