develer
Oct 21, 2025Aspirant
Enable DHCP snooping on
I have an Insight Managed 52-Port Gigabit Ethernet PoE+ Smart Cloud Switch with 2 SFP and 2 SFP+ 10G Fiber ports (GC752XP) from 2018.
Is there a way to enable DHCP snooping via Insight?
Under Wired > DHCP snooping I can see only the ports of a MS510TXUP.
Thanks in advance
Not on these very early Netgear Insight switch models like the GCxxx. The required "feature" was added later along with some newer Netgear Insight manageable switches only.
Of course, the ability to manage DHCP Snooping is readily available on the local Web UI - Netgear Insight neither required nor prohibiting the local configuration required.
- Feb 20, 2022Retired_Member
