develer
Oct 21, 2025Aspirant
Enable DHCP snooping on
I have an Insight Managed 52-Port Gigabit Ethernet PoE+ Smart Cloud Switch with 2 SFP and 2 SFP+ 10G Fiber ports (GC752XP) from 2018. Is there a way to enable DHCP snooping via Insight? Under...
sonofgohan
Oct 31, 2025Aspirant
DHCP snooping isn’t supported on the GC752XP via Insight. You’ll need to enable it manually through the local web interface or CLI — Insight only shows compatible models like the MS510TXUP.
- Feb 21, 2022Retired_Member
