fredrikmont
Jul 06, 2019Aspirant
How to connect two switches - gc510p
Hello, I wonder how (if possible) to connect two gc510p switches? When I try with a cable they do not connect, so I wonder if there is a setting I need to modify or how to do it. Thanks for any su...
- Jul 16, 2019
Sounds a liiiiiitle bit dangerous for this job 8-0
Give him some assistance - convinced in the team you manage it. Same time you learn on how to make the cables and the installation, it's not difficult in general.
Be very picky that exact the same pairs are set-up on the screw ports of the wall outlet. If this still does not allow Gigabit Ethernet, consider to replace the wall ports by at least CAT5E (betterCAT6A) capable plug system intended for network installations.
schumaku
Jul 16, 2019Guru - Experienced User
fredrikmont
Jul 16, 2019Aspirant
I certainly agree... not ideal to be color blind when you are an electrician!
I will do and appreciate your support to nail this issue down!
Thanks Kurt
