BretD
Feb 16, 2018Administrator
How to Create a VLAN with Insight Management #Tutorial #Video
Creating a VLAN with your Insight Managed Smart Cloud Switch is easy from the Insight Management App.
For the detailed tutorial visit the NETGEAR Insight Knowlegebase.
Here's how to create a new VLAN in Insight Management
1. Open your Insight App
2. Tap on a switch in your network
3. Tap “VLANs in use”
4. Press the plus sign on top right of screen
5. Tap the type of network you want to create
6. Create your VLAN name and ID
7. Tap Save
Marked as solved
1 Reply
- BretDAdministrator
Marked as solved
