mihonukr
May 30, 2023Aspirant
How to enable ssh on GC728X ?
I try this solution https://blog.hansguthrie.com/2016/01/27/enable-ssh-on-netgear-gs728tp/ but it didn't work
schumaku
May 30, 2023Guru - Experienced User
Interesting question, especially considering there is no supported CLI or CLI Lite on these switches at all, and telnet is supported for diagnostic purposes only...
- mihonukrMay 31, 2023Aspirant
Found this one
https://docs.netapp.com/us-en/ontap-systems-switches/switch-bes-53248/configure-ssh.html
- AnishaAJun 05, 2023NETGEAR Employee Retired
Hello mihonukr ,
And welcome to the NETGEAR Community! 🙂
Have you tried the link you have mentioned below and are you able to enable ssh also you can try the below link once for enabling ssh?
And for troubleshooting purposes, we usually enable remote diagnostic mode.
We also can access the files via ssh using the RSA key for the pem file.
If your issue is resolved please close the thread by clicking "Accept as solution".
Have a lovely day,
Anisha A
Netgear Team
